Streamline your workflows and master BIM coordination! Program starts April 28.!
rotating in 3D
peter spellman
Is there movement with future archicad versions to allow for free form rotation in 3D? I know about morph's, etc which can be done now, but what about for objects? The current system is really cumbersome to say the least.
Thanks!
Lingwisyer
Guru
I do not recall there being anything on the roadmap.
https://graphisoft.com/product-roadmap
For now, there is an object called Rotator which you can use. It can be found by just searching for it in the object library dialogue. It has some limitations but it might be good enough for what you want.
Ling.
Lingwisyer
Guru
Ling.
peter spellman
I will check it out. hanks Ling!
