rotation of objects.... ?
I need to rotate some objects -
for example:
- how do you rotate a pipe (column or basic shapes) so that it can be
angled at 4:12 ?
- how do your rotate a 1/4 round shape (basic shapes)?
thanks guys.....
2 Replies 2
Djordje
Check the object for rotation parameter; something like the attached
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
for example:
angled at 4:12
In addition to Djordje's response - where the lib parts have a param for rotating about the X or Y axis - the next thing is to convert your 4:12 pitch to an angle in degrees. No need to do the math. Just open the roof tool settings and use it as a conversion calculator: select 4:12 or whatever and then change the units display to degrees, read the result, and use that for your parameter value.
