2013-07-03 05:33 AM
2013-07-03 05:41 AM
2013-07-03 06:22 AM
2013-07-03 06:37 AM
2013-07-03 03:50 PM
3d4draww wrote:The spacing of the dots can be adjusted in the Fill Types dialog box. Or you might just change the Gypsum Board fill to a different fill with no dots.
For fun tried to adjust gyp fill itself but no option there, or maybe I could play with the "on screen" dots. I'll duplicate and play with that later.
2013-07-03 04:39 PM
s2art wrote:Thanks Stuart
It's also going to depend on where your wall is situated. Move it a few millimetres and you might get a different outcome. Depending on the scale of your drawings it probably isn't an issue anyway, is it?
2013-07-03 11:24 PM
2013-07-04 08:40 PM
MarkMoscrip wrote:Thanks Mark, nice tip.
I have begun using percent fills for these situations. They are uniform regardless of scale or position.
2013-07-05 03:00 PM
3d4draww wrote:Just looking at your screen shot, there are 2 different fills assigned to the 2 gypsum board layers: "Gypsum Board" and "09 | Gypsum Board". Shouldn't these be assigned the same fill?
I'm I missing the obvious?
2013-07-05 03:57 PM
David wrote:Now that's embarrassing3d4draww wrote:Just looking at your screen shot, there are 2 different fills assigned to the 2 gypsum board layers: "Gypsum Board" and "09 | Gypsum Board". Shouldn't these be assigned the same fill?
