sash on 2d wanted not to be crossed but trimmed
Hello every one my question when i place window on archicad and using sash its represent on 2d eleation is not trimmed on all edges how can i make it trimmed through setting in archicad (i attached my image to make my point is clear)
second how i can make opening line not appearing on elevation
Thanks in advance
4 REPLIES 4
Finally i found solution for this and i will not be stingy of course with this nice forum so i will share with you the solution i discovered
if you want what called grills or mullion in the window being trimmed during crossed line just choose in the window setting --under sash options --Editable Grid instead of H-V Grid (i attached the image for further clarification)
but i still do not know how to remove opening mark from 2d elevation i know it simple but i can not reach to the option removing it
Thanks for this nice forum
vistasp
model view options
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
David Maudlin
vistasp wrote:
model view options
Also check the Opening Lines panel in the window's settings, there is an override for the Model View Options in AC 14.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
vistasp
Oops! Missed that possibility which was introduced in 14.
= v i s t a s p =
bT Square Peg
