scaling .dwg file import
I seem to be having a problem scaling a surveyor's plan into Archicad. upon importing into archicad, what ia dimensioned as 100' in the Autocad drg measures 8'4". I have resized the imported drg so the marker 100' actually measures 100'. Are there any drawbacks to this method? if I were to scale before importing, what is the raio I would use? The translator seems only to offer 1mm, 1m 1 inch etc. looks like this ratio is a bit odd (8'4" = 100')
5 Replies 5
Stephen Dolbee
I've had the same problem importing autocad drawings from surveyors. I don't think there are any drawbacks to your method. That is how I have done it. I think the ratio depends on what scale the surveyor used. In your case 12:1.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
TomWaltz
It's smaller by a factor of 12, which means you should change the import unit to 1" instead of 1'-0",
Tom Waltz
David Pacifico
It's off by a factor of 12
Civil dwgs always need to be brought in 1 to an inch.
Everybody else 1 to a foot.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
I think you have it reversed (or I don't understand you correctly). The drawing units for a civil drawing are typically set to one foot. If it is translated using the architectural standard of one inch then everything will be one twelfth of its correct size. Similarly if everything comes in 25.4 times too big then the source file was in mm.
David Pacifico
Yes, sorry, I had it mixed up.
Civil set to 1 to a foot.
David Pacifico, RA
