ETSaum
RFA + RVT Files "could not be imported"
Trying to import either RFA or RVT files from two different sources for some commercial vent hoods. The correct processes were followed for each, so that's not the issue.
In each case, I got an error message, saying that the file "could not be imported".
"Try checking the file with the original author to solve the problem, and please be aware that only file versions 2015-2024 are supported."
Has anybody else run into this? These are files downloaded directly from the manufacturer and / or BIMObject.
Edward Saum
Windows 11, AC Version 29
[email protected]
2 Solutions
The answer is in the message.
The files are probably in a format older than 2015 or possibly in 2025 format, which Archicad can not read.
Go to post
Lingwisyer
Guru
You can apparently check the version of RVT files by opening them in Notepad or similar and searching for "b u i l d"
Go to post
5 Replies 5
CosminF
Hi! I have also encountered this issue with some supplier-sent model (on both rfa and ifc files they provided) and asked them if they could re-save the file and afterwards the issue was gone.
Prior to this, I have tried opening them from two different pc’s and it wouldn’t load.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Lingwisyer
Guru
ETSaum
Today I learned!
Sure enough, most of the files giving me grief are Revit Mechanical 2010 files.
Edward Saum
[email protected]
Lingwisyer
Guru
Revit files not being reverse compatible has always been such a...
