sea level?
hi, as you can find out from my topic, i am a beginner of archicad 10.
(I used to autocad) I am going to start drawing for three storey building.
whatz sea level and when I draw ground floor plan, just can I draw walls and slab stuff from 0.00 level?
Dwight
You can ignore sea level.
This is just a way to relate building heights to aerial survey data.
If you are making things up from scratch, then who cares until the ocean floods in?
Dwight Atkinson
you are right.. thanx
David Maudlin
iconplus:
If at some point you need to reference Sea Level, you can go to Preferences > Working Units & Levels > Reference Levels to create another reference height.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
