section of the home
hello,
I want a whole section of the home (see photo). How do I fix it archicad
Do you mean how to get full 3d view back?
One way.
In 2d re-corral the entire model with heavy marque and reactivate: Right click>Show Selection...
Kinda like how you got cut look.
(if in windows)
Mac is probably similar.
Best to make a profile for future posts.
adzik
Just hit Ctrl+F5 in any window to get the whole model to show in the 3D window.
Running ArchiCAD 23 INT.
Use the THICK MARQUEE to select desired part of the plan and then pick the right button and select "Show selection/Marquee in 3D".
