selection and element information
How can i have consecutive selection in archicad 16 (one by one), by simple click, like archicad 11, 12, 13, etc.
4 Replies 4
Hold the TAB key while selecting.
I knew of the selection with tab key, thanks anyway for your reply, I appreciate it. My question was if I can select without type ''tab'' , achicad 13 version can do that, just typing left-click several times. ''Tab'' key is an order made in addition in archicad 16. Thanks for your help.
Eduardo Rolon
press Shift+Click to add to the selection if i understand the question.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
This previous post might help you.
http://archicad-talk.graphisoft.com/viewtopic.php?p=216854
It seems you will need to turn of the "quick select" magnet.
