selection problems
Sangho Ryu
In Archicad, when I select a 2D object individually, there is usually a 1-2 second delay before the toolbox appears. However, when I use the Arrow tool to select objects by area, the object description window pops up immediately. Why does this happen? I would like the screen to switch instantly even when selecting objects individually.
Operating system used: Mac Apple Silicon sequoia
Karol Argasinski
Hi Sangho,
check this thread: https://community.graphisoft.com/t5/Modeling/Apple-M1-Units-I-select-items-and-they-always-want-to-m...
If you have Magnet installed, you should close it and it should work well (I see you have an icon). I had the same issue on M3Max and this solution worked for me.
Best
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26/27 INT &POL
AMD Ryzen 7 3700X, 128GB RAM, GeForce RTX 3070, Windows 11 Pro
MBP 14 M3 Max 16C/40G, 128GB, 2TB
http://www.bimfaktoria.pl/
Karol Argasinski
Hi Sangho,
Best
Karol
OPENBIM does works!
Sangho Ryu
oh my god!!! Thank you so much
it was solved immediately.
Happy to help Sangho Ryu, real kudos to @furtonb  😎
Best
Karol
OPENBIM does works!
Setup info provided by author
