2010-02-02 11:17 PM
2010-02-08 12:45 AM
2010-02-08 01:25 AM
2010-02-08 02:55 AM
2010-02-08 03:16 AM
2010-02-08 03:22 AM
2010-11-05 09:44 PM
2010-11-06 01:21 AM
johncassel wrote:
Aloha Erika,
Ideally what I would like is that the walls showed up on each plan as follows. I could use your help and guidance on how to achieve this.
Site Plan with the walls show as solid line outlines showing where the doors and window openings are without any door or window details.
If all the Site information is placed on the same Story as the Said walls just set your Model View Options for Doors and Windows to "Show Opening Only" and check the "with Contours".
Floor Plan with the walls, doors and windows shown as solid lines showing all of the door and window details and markers.
Model View Options with Doors and Windows to "Show On Plans" and check the "with Markers".
Foundation Plan, Floor Framing Plan and the Roof Plan showing dashed outlines of the walls with the openings and contours for the doors and windows.
Foundation -On the Foundation story (usually one or two stories below story 1, depending if there is a Pony [build-up story]) I use a Complex Profile for the Stem and Footing and Like the Stem Solid and the Footing as Hidden Line. So I set the Floor Plan Cut Plan (FPCP) through the Stem Wall (Which does not always work well on a Sloped lot that has Foundation walls that may be 6 to 10 feet in elevation difference to the top of wall). Then set the walls Outlines > Uncut Lines to Hidden (or Dashed as you like)
Floor Framing - On the Foundation Story have the FPCP above your Foundation walls and again have the walls Outlines > Uncut Lines to Dashed
Roof Framing Framing - I don't know if I like any of my Dashed options here because the solutions involve having the FPCP Above the walls and I would prefer having the FPCP go through the Openings so that they are seen. So on the Story which containd teh main walls set the FPDP above tallest wall and in the Relative Floor Plan Range: Show Up to: 1 Story above (or Current story) but Offset by the Same distance as the previously set cut plan height oif current story. And again have the walls Outlines > Uncut Lines to Dashed
And for all these views set Model View Options for Doors and Windows to "Show Opening Only" and check the "with Contours".
Roof Framing showing dashed outlines of the walls with openings and without the contours for the doors and windows. I prefer not to show the contours for the doors and windows on the Roof Framing Plan so I can draw in the door and window headers.
Yes My above options do not allow for the Openings to be Shown. Maybe that is why it is a Problem.
So I would look into making a Composite wall with the Core Lines as Dashed (although maybe not good for other views) and set the Framing Plans to Partial Structure Display to Core only.
Is it possible to get this as live projections of the modeled walls?
I have a work around for the Site Plan that is working for me. The thing I would really like to be able to do is to show structural plans with the walls as dashed lines and the doors and window openings as dashed lines. Can you tell me how to do this from the live version of the walls, doors and windows?
I blew it with most of the above discription(but look at that word count) because the started Splaining before I have all the facts. I would look into the Dashed Composite core option
Thank you,
John
2010-11-06 01:57 AM
2010-11-06 11:43 AM
johncassel wrote:
The set of plans that I outlined above should be a snap for the software that I use
I would be happy to sit down or communicate with the ArchiCAD developers the simple features that are needed to easily create a simple set of architectural plans for residential architecture. I would imagine that there might be a pool of ArchiCAD user who would be willing to to do this. I think that it would a great for the developers to open up to this kind of informed input from the users.
