‎2007-07-12
10:29 PM
‎2023-05-25
04:59 PM
Rubia Torres
‎2007-07-12 10:46 PM
Chris wrote:Stairmaker has not been updated since... uh .... 2000? 1999? so if it did not do it in 2004, it still doesn't, but I would not give up just yet on another way.
I'm a new user trying to create a simple stair as shown in the attachment using stairmaker but I haven't found any combination of settings that does the trick - the winders always continue around the square landing area and won't meet at a single point.
I found an old post that indicated stairmaker just wasn't able to do this but since it was from 2004 I wanted to check in case there was an improvment made since then that would help.
I'll get archistair if needed but I was hoping to put it off a little longer as I just spent a good deal of money to by AC...
any help appreciated!
‎2007-07-13 03:41 AM
‎2007-07-13 05:59 AM
‎2007-07-13 05:31 PM
‎2007-07-13 05:48 PM
‎2007-07-13 07:33 PM
Matthew wrote:I believe the narrowest portion of the tread have to be 6" depth minimum according to CBC. It sure doesn't look right to me.
Is that stair legal in Santa Barbara?
‎2007-07-13 09:20 PM
Matthew wrote:As Dennis States below, the stairs are not legal.
It's getting pretty hard to get winders to pass inspection.
Matthew wrote:I do not want to go on a Engineer vs. Architect rampage (as most of you out here in cyberspace seem very conscientious), but Stair design, or the lack there of, is one of the weakest area in design an thought that I see in many plans.
I have seen far more mistakes in designing, drawing and building stairs than any other building assembly. Cutting the stringers for just a single straight run of wood stairs takes a pretty skilled carpenter.
‎2007-07-13 09:28 PM
‎2007-07-13 09:29 PM
