simple stair winders
I'm a new user trying to create a simple stair as shown in the attachment using stairmaker but I haven't found any combination of settings that does the trick - the winders always continue around the square landing area and won't meet at a single point.
I found an old post that indicated stairmaker just wasn't able to do this but since it was from 2004 I wanted to check in case there was an improvment made since then that would help.
I'll get archistair if needed but I was hoping to put it off a little longer as I just spent a good deal of money to by AC...
any help appreciated!
12 Replies 12
TomWaltz
Stairmaker has not been updated since... uh .... 2000? 1999? so if it did not do it in 2004, it still doesn't, but I would not give up just yet on another way.
Is the screenshot what do want or what you do not want? Are you using the simple Archicad objects or building your own in Stairmaker?
Tom Waltz
the screenshot is what I want. I tried the stock AC stairs and also using stairmaker as well. I kept playing with the different values but no luck...
thanks for the help!
Stress Co_
It maybe easier/faster to just model it out of slabs.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Jere
It can be done by modelling a custom stair using a fill pattern, line, and arc. It won't work with the points matching up unless you have a 0" nosing. That's actually realistic. Are you sure it's necessary to actually have them meet exactly? It's probably more tricky to build it that way.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Is that stair legal in Santa Barbara?
It's getting pretty hard to get winders to pass inspection.
BTW: I don't believe there is such a thing as a "simple" stair. I just finished making some custom stair parts for a client which are designed to make just the most basic concrete and steel stairs. Making them "simple" has been a terrifically complex task.
I have seen far more mistakes in designing, drawing and building stairs than any other building assembly. Cutting the stringers for just a single straight run of wood stairs takes a pretty skilled carpenter.
Dennis Lee
I believe the narrowest portion of the tread have to be 6" depth minimum according to CBC. It sure doesn't look right to me.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
As Dennis States below, the stairs are not legal.
I do not want to go on a Engineer vs. Architect rampage (as most of you out here in cyberspace seem very conscientious), but Stair design, or the lack there of, is one of the weakest area in design an thought that I see in many plans.
Thanks for the input and suggestions. I should probably have mentioned that the plan is an as-built - as was mentioned, the stair would not be legal today but was in the past.
overalll, it sounds like I need to either model it myself or get archistair especially as even if it were a new stair, I don't like the apparent lack of control over which treads are angled and by how much.
rjwilden
Here in NZ the going or tread is measured at the walking line,which is 450mm out from the stringer. So that stair is legal here. Makes sence as you cant walk hard up against the handrail any way.
Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
