sinks in tabletops
I have taken a sink from the D3 kitchen and bath library, and I want to place it in a table for a restaurant kitchen. The table is showing through, and I need some ideas on how to get rid of that. Is there a way to sort of cut a hole? I'll take any ideas.
1 REPLY 1
Try Solid Element Operations (SEOs) in the Edit menu. If the sink is modeled with solids in the GDL it should work just fine. Use "Subtraction with upwards extrusion."
