2007-09-24
10:29 AM
2023-05-25
05:54 PM
Rubia Torres
2007-09-24 10:39 AM
2007-09-24 11:30 AM
2007-09-24 06:15 PM
2007-09-25 07:52 AM
Kelly wrote:I have also seen computer crashed on complexed complex profile, maybe a memory issue?
Thanks Dwight,
That's worked, the only problem is that every computer i try it on crashes when I try to see it in elevation. Nevermind, might just have to do it by hand
2007-09-25 07:57 AM
TurboGlider wrote:Computers crash because the memory problem they have is that they forget.Kelly wrote:I have also seen computer crashed on complexed complex profile, maybe a memory issue?
Thanks Dwight,
2007-09-25 11:58 AM
Dwight wrote:I guess it is BUG!!!!!!!!!!!!TurboGlider wrote:Computers crash because the memory problem they have is that they forget.Kelly wrote:I have also seen computer crashed on complexed complex profile, maybe a memory issue?
Thanks Dwight,
2007-09-25 04:50 PM
2007-09-25 05:53 PM
2007-10-01 04:02 PM
Robert wrote:Hi,
If it doesn't have to be a wall then maybe you could just save
it as a library part. Just select the slabs/ switch to perspective side view/
set the Azimuth to 90 or 270 (which ever end need to be up) and save
it as a library part. Hope this helps.
