solid element operations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2022-08-10 11:38 AM
I was cutted slab with morph profile/shape for slop shape, than morph put in to hidden layers , after than create wall on the top or other element so all objects was cutted same as well morph profile , how do i just slab cuting with solid element operation,
thankyou
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-08-10 01:45 PM - edited ā2022-08-10 02:56 PM
If you want to stick to this modeling method you should put the upper wall onto a different layer which has a different intersection priority number and repeat the SEO with the same operator.
Example here - the upper wall layer was set to wireframe for a better view and I used two single plane roof elements for operators:
| Archicad 4.5 - 29
| HP Z840 | 2Ć E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2022-08-10 02:45 PM
You went by difficult way, instead to use the roof for a slope and then all the walls trim to roof.
AC 8.1 - 27 INT/POL 3001
Win11 | Ryzen 5600 | 16 GB | GTX 1650
