solid elements operation and find an select
hi iam a new archicad user .when i try use solid element operation option nothing happens when i click on execute, is there something iam missing?.....also when i try to select multiple things using the find and select option it doesnt show a place where i can type the name of what i want to select...
5 REPLIES 5
Eduardo Rolon
The Operator on the SEOs have to be placed on a specific layer (z-SEOs for example) and that layer has to be turned off.
Find and select picks the settings from the object that you have selected using the icon with the square and arrow.
Not all the fields can be written to.
The procedure basically is:
1. select object that has the settings you want to use for F&S
2. Hit the button for the square
3. Keep adding to the fields by using the Add button
4. then hit the Plus sign to select them
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
David Maudlin
Some SEOs do not affect the plan view (depends on the type of elements involved). Some Objects, Single Plane Meshes and Single Plane Morphs cannot be operators, and there are other restrictions; so you will need to post more information to get a better answer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
okay am using archicad 17, windows 8 o.s...iam trying to design the bathroom such that part of the wall finish is tiles upto a certain hieght , so what i have done is i have drawn another thin wall but when i use SEO to burry it on the other wall nothing happens
David Maudlin
dennis kip:
Works here, try posting some screen shots of 2D, 3D and section and maybe someone can identify the issue.
It will depend on the priority strength of the original wall and the tile wall. If the original wall is stronger it will over-rule the tile wall before you get a chance to do the SEO.
When I have done this I just use a tile wall overlay, rather than trying to bury it in the original wall. After all, this is how it will be built.
