solid fill visibility in elevation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-03-02 05:59 AM
2012-03-02
05:59 AM
Kathryn
Archicad version 19
Windows 10
Archicad version 19
Windows 10
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-08 09:16 AM
2012-03-08
09:16 AM
Is there anyone out there that can help me with this???
Kathryn
Archicad version 19
Windows 10
Archicad version 19
Windows 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-08 09:48 AM
2012-03-08
09:48 AM
I can confirm that % fills do not show up when linked to a material.
I can't say why not though.
I just use a solid fill with a light grey pen.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-08 11:16 AM
2012-03-08
11:16 AM
Thanks Barry,
It is a pity though that a solid fill in a light pen doesn't work if I am setting up my drawings to be black and white. Our office still uses coloured lines to represent the different line thicknesses so I can't set the drawings to match the pen set or to grey scale as then the lines won't show properly. I guess I could create a new pen set for internal elevations that is all blacks and greys . . . . anyway, thanks for confirming what I suspected.
cheers,
Kathryn
cheers,
Kathryn
Kathryn
Archicad version 19
Windows 10
Archicad version 19
Windows 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 09:41 AM
2012-03-22
09:41 AM
This is interesting.
I have just come across a plan that has % fills attached to a material in the elevation and they show up fine.
So it is possible.
The mystery is that these are new fills that have been created.
If I swap this new % fill with the original % fills (25%, 50%, etc.) then the fill in elevation disappears.
If I add the new fill to a material and then attach that to an element the fill appears.
So it seems like there is something wrong with the default original %fills.
I have tried to create a new fill from these original fills and they won't show either.
I have also tried to create a new fill from the solid fill and given it 50% transparency and it will not show either.
So the thing is to now find out how these new fills were created.
I will be sure to post back if I find the answer.
So it is possible.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 09:42 AM
2012-03-22
09:42 AM
And just to prove the wall can have a % fill on the material.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 09:52 AM
2012-03-22
09:52 AM
OK I have the answer.
You need to create a new fill but make sure you choose the "Solid" option.
Once created then you can set the level of transparency %.
Attach this new fill to your materials and it will show up fine in the elevations.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-22 10:06 PM
2012-03-22
10:06 PM
Awesome Barry,
Just created a 50% fill as directed and it works fine.
You've made IE's just that little bit easier.
Thanks heaps!
Kathryn
Thanks heaps!
Kathryn
Kathryn
Archicad version 19
Windows 10
Archicad version 19
Windows 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-03-23 03:20 AM
2012-03-23
03:20 AM
6 "Awsomes".
It must have been good advice.
