Jefferson
special menu help
Having trouble locating anything in the help menu [operating under the assumption that this is a duplicate of the manual] that describes functions and or uses of the tools/functions unknown to me. [I'd like to have a better idea about these before I just start turning things on and off. I regularly toggle show special lines, have enable special features checked, and render without autosave. ]
Can someone point me in the right direction please.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
22 Replies 22
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Using 9 it's just a bit more difficult.
You should use Regedit (like before) to enable it and then you should use the WorkEnvironment function to add this menu.
I still never tried under Mac, I suppose you should do like before for the first step (using ResEdit) and then, once again, WorkEnvironment dialog window to add the menu.
Let me now if anything is clear...
Friendly
Fabrizio
for Ben: Wow, what a wonderful Avatar I was there, near you, when you take that picture!
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Dwight
I went into ResEdit to find the MENU unit, but it is not there - in prior versions it was easy to find.
So, yes, if you can give me a road map to find the DLOG I can check the little box inside....
Dwight Atkinson
__archiben
Ben wrote:
There is one more way you can do it without any editing, if you simply hold down APPLE+CTRL while starting up ArchiCAD, it will appear.
I hope it is those 2 keys, it's ALT+CTRL on the PC, so that's why I'm assuming it is APPLE+CTRL on the MAC.
okay . . .
things have changed with 9 (mac at least) - you need to alter/edit/hack the archicad plist file in order to see the special menu! just install your developer tools. it's easy!
if i get a moment later i'll fire up the laptop and see if i can work out a step-by-step using only a text editor . . .
ben O - do you have that picture big-stylee? if so, could i ask you to mail it to me when i next get my laptop online? (working from webmail in SE asia internet cafe's at the moment...)
cheers
~/archiben
b e n _ f r o s t
Ben Odonnell
Ben, Dwight.
Sorry for the misleading information. You are both right, it is different in ArchiCAD 9. Ben's plist instruction is the way to do it.
Ben I have all of the photos that were taken that night. I sure do have my avy large size . It's a great pic!
Just drop me a line and I'll mail you all of them if you want them all.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Dwight
I forgive you since you are getting ready for the "big dark" up there - what is your lattitude? Dark enough here at 49 degrees North. Stocked up on pickled herring? I know I am. Muktuk, too.
Dwight Atkinson
Durval
Therefore, I suppose the following page in ArchiCAD 9 Help deserves a little update, as the key combo doesn't work on Macs as stated:
Introduction to Object Making > PART ONE: OBJECT MAKING WITHOUT GDL > Chapter 1: Introduction to Object Making > Sources of Library Parts
"Using old libraries - update library parts
"(...) You can speed this up by opening ArchiCAD with the Special Menu visible. Boot up ArchiCAD holding down the Opt-Cmd keys (Mac) or Alt-Ctrl (PC) - you will see the Special Menu appear. (...)"
--- www.dtabach.com.br ---
AC 28/29 BRA – MacBook Pro Apple M2 16GB RAM Mac OS Sequoia
Still having trouble with this on Mac OSX and AC 9.
I've got a plist editor (nice tool called "Pref Setter" linked from the Apple OSX support page). I can find the Special Menu plist item, change it to "true", close file, open again to confirm the setting took, and...
No change upon opening AC9. Sniffing around in the Work Environment settings didn't reveal a Special Menu item either. I also tried some key combo's to see if they worked once the plist was edited. No dice.
Who is doing this on Mac OSX and AC 9.00 v1?
Thanks.
__archiben
RobertNichols wrote:
Who is doing this on Mac OSX and AC 9.00 v1?.
i am.
see attached sceenshot. once you've enabled it by way of editing the prefs (which sound successful), you need to add it from the available menu to those in use. find it in the left hand column as shown and drag it to your preferred position in the right hand (in use) menus . . .
hope that makes sense. usual disclaimer applies: use the special menu at your own risk.
cheers
~/archiben
b e n _ f r o s t
Dwight
How about this:
I enabled the Special Menu and it appeared on the list of Toolbars, not Menus.
So I made it a toolbar.
haha.
Dwight Atkinson
I get the same result, Dwight, toolbar only....
