special menu help
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2004-09-22 11:44 PM
ā2004-09-22
11:44 PM
Can someone point me in the right direction please.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
w3d design
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
22 REPLIES 22
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-01-27 10:41 PM
ā2006-01-27
10:41 PM
"On Mac first you need to edit the plist file:
Open Users / username / Library / Preferences / com.graphisoft.AC 9.0.0 USA v1.plist file, find the Special Menu key and set value TRUE instead of false (just rewrite in the file, and save), then start ArchiCAD 9.
In Windows:
1.) Edit the Registry via the Run-> "regedit" command
2.) HKEY_CURRENT_USER-> Software-> Graphisoft-> ArchiCAD-> (version)-> Special Menu (value = '1' instead of '0')
3.) Next go to the Options-> Work Environment-> Command Layout Schemes-> Menus -> Customize Menus-> 'Build or edit this menu' right column-> Menu Options-> New Menu-> name the new menu "Special"
4.) Customize Toolbar-> Application commands and menus-> List-> (drop-down menu)-> "All Commands by Theme"
5.) In the same column-> Select the "60 Special" and add the tools you want in the center column (Application commands and menus) to the right column of "Special" (the menu you created)
6.) After closing the dialog the new menu "Special" will appear in ArchiCAD 9.
In Windows:
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-05-01 03:23 AM
ā2006-05-01
03:23 AM
I just used PlistEdit Pro to turn on the special menu. Started up ArchiCAD and it appeared immediately between Window and Help. Piece of cake. I did not need to add it to my WE, not sure why.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
Geoff Briggs
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-05-01 05:40 PM
ā2006-05-01
05:40 PM
If you are using Windows Run regedit.exe and go to
HKEY_USERS\S-1-5-21-2061591027-1542749521-168829947-28821\Software\Graphisoft\ArchiCAD\ArchiCAD
9.0.0 USA R1\
You will find there Special Menu key - change it to 1
9.0.0 USA R1\
- Ā« Previous
- Next Ā»
- Ā« Previous
- Next Ā»
