Jefferson
special menu help
Having trouble locating anything in the help menu [operating under the assumption that this is a duplicate of the manual] that describes functions and or uses of the tools/functions unknown to me. [I'd like to have a better idea about these before I just start turning things on and off. I regularly toggle show special lines, have enable special features checked, and render without autosave. ]
Can someone point me in the right direction please.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
22 Replies 22
Rakela Raul
"On Mac first you need to edit the plist file:
Open Users / username / Library / Preferences / com.graphisoft.AC 9.0.0 USA v1.plist file, find the Special Menu key and set value TRUE instead of false (just rewrite in the file, and save), then start ArchiCAD 9.
In Windows:
1.) Edit the Registry via the Run-> "regedit" command
2.) HKEY_CURRENT_USER-> Software-> Graphisoft-> ArchiCAD-> (version)-> Special Menu (value = '1' instead of '0')
3.) Next go to the Options-> Work Environment-> Command Layout Schemes-> Menus -> Customize Menus-> 'Build or edit this menu' right column-> Menu Options-> New Menu-> name the new menu "Special"
4.) Customize Toolbar-> Application commands and menus-> List-> (drop-down menu)-> "All Commands by Theme"
5.) In the same column-> Select the "60 Special" and add the tools you want in the center column (Application commands and menus) to the right column of "Special" (the menu you created)
6.) After closing the dialog the new menu "Special" will appear in ArchiCAD 9.
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
SeaGeoff
Ace
I just used PlistEdit Pro to turn on the special menu. Started up ArchiCAD and it appeared immediately between Window and Help. Piece of cake. I did not need to add it to my WE, not sure why.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
If you are using Windows Run regedit.exe and go to
HKEY_USERS\S-1-5-21-2061591027-1542749521-168829947-28821\Software\Graphisoft\ArchiCAD\ArchiCAD
9.0.0 USA R1\
You will find there Special Menu key - change it to 1
