Streamline your workflows and master BIM coordination! Program starts April 28.!
splayed / angled window openings
Does anyone have a good method for creating splayed window openings?
I know there is a splayed reveal object but with no window. I have tried placing the window I need inside of the opening but the display is messy and needs 2d patching. Any better ideas?
Thanks, Matt
11 REPLIES 11
Matt,
Do you mean that you have to mask the edges of the opening
when you use the splay niche opening and if you have a hatch pattern
cut fill in your wall you have to put a fill between the outside
edge of the casing and the outside of the frame of the window
you are placing in the opening ?
Peter Devlin
Erich
Matt,
If you mean a window with a splayed opening to the outside there was a discussion of this within the past year about just that for a window in a stone wall. It involved a splayed window and some SEO operations on the outside if I recall correctly. A search may pull it up.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Erich
Matt,
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
This may be helpful?
http://archicad-talk.graphisoft.com/viewtopic.php?p=93992
Pete.
Erich
Thanks Peter,
That was the topic I was thinking of, I just did not have time to find it just then.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
The below is quoted from the referenced post. Is that he best way to do it? Crazy that we don't have chamfered openings also!
eah, that double chamfer looks like a bear to do.
You guys are lucky at least to have the single side chamfer. The US library only has an empty opening which has to be added to and aligned with an actual window.
Aside from making custom windows or working with SEOs and patches, the only fairly simple way to do it is to put two walls back to back and align the window in one with an empty, chamfered opening in the other.
_________________
Matthew Lohden
Consultant
North Bay Area, California
MacBook Pro 17"
MacOS 10.4.9
WinXP SP2
One way to do this with the only
splay reveal we have is the following.
Draw the thick wall, and insert the
w splayed reveal 10 opening into the wall.
Set the splay angles, opening dimension,
and frame depth you want. Draw another wall
that is set to the thickness of the frame depth
set in the splay reveal parameters,
is as high as the opening, and base elevation
set to the height of the sill of the opening.
Disable both wall ends and draw this wall
in the opening and bring it forward one step.
Now stretch both ends of this wall slightly
so that it's ends just mask the opening's contour lines.
Insert an ordinary window into the thin wall.
Peter Devlin
undefined
And here is a section
undefined
Thanks for all the suggestions - I've downloaded the Int. library, extracted it and pulled out the windows I need. However, I was getting missing macro errors so I copied the scripts it looked like I needed into my newly created window library and the window works fine....but I get duplicate library parts warning now. I have deleted all of the macros that seem unrelated and that has reduced the number of duplicates. Would I need to rename every macro, UI image, etc. to have no duplicates? Does it ever matter if I have duplicates - can I just leave it alone and use it?
Thanks, Matt
