ares997
Meshes
It would be great if the meshes could have a option to show the individual point elevations, similar to that of a civil survey, so you could either show the individual elevations for each point. Also it would be nice if the mesh could have an option to look similar to that of survey with the contour lines or points. So basically three different options; Point elevation identification mode, contour line interpretation mode, normal standard. Why would this help. Well it's hard to go through the whole mesh to figure out what points are off, and if they are off it takes a long time to get to the point where you are able to correct the problem consistently.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
0 Replies 0
