split levels
I'm trying to model a building which has a split level, but every time I try to add in the half levels it pulls apart the levels at the other side of the building.
Does anyone know who to increase the level by half without interfering with the floors that have already been created?
Thanks.
you should just put both levels of the split level onto one story, then you will probably need to make some of the walls symbolic cut, or adjust the floor plan cut plane to adjust the final look
