stair slab fill problem
hello!
Can anyone tell me why I cannot connect those fills?
6 Replies 6
In stairmaker, try changing the lower floor connecting thickness the stair connects to, to zero.
The fill should join correctly now as it is sitting flush with the top of the slab.
You could also try subtracting the stair from the slab using SEO, if that is the correct detail you are after.
yes!! Ive never thought to put there zero, I always use the exact slab thickness. Thank you very much!
Happy Weekend!
Djordje
INT version does not let you put zero there ... at least IMHE.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Erika Epstein
What do You do to get around this? SEO?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Im sorry I dont know what IMHE is but I have v.11 and zero worked yesterday, and my problem was solved! Thank you 🙂
Maybe Djordje meant that it doesn't work in v.10 (I forgot to change my signature )
Djordje
Duh ...
I am working in 10 last few months, for compatibility reasons ... no zero there.
IMHE is In My Humble Experience
Djordje
HP Omen
