stories setting
can anyone help me with this.......i can't understand how that dormer/roof elevation is 312" when it is 230" with the dimension tool measures from 108" on the section/elevation.
ver7.0 on xphome!
Aussie John
I suspect you have set out your elements relative to the origin rather than relative to the storey
Cheers John
[/size]
How you measured it ? . Elevation shows you the height (height above project ZERO) of story. It is described by you. You cannot measure it on plan or section, until you will have element on ZERO of dormer/roof story, and you measure the distance between this element and project ZERO on section.
