Llian
story settings number
In the ITG-Essential tutorial, the pln story settings are shown as -1, 0, 1, 2....but the movie is showing a running number from -1, 1, 2, 3..... How do I change the pln to match with the movie?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
This is a difference between the INT and the USA versions.
In the USA version there is no Story 0, stories above ground start with Story 1.
The videos you have downloaded are showing the AC INT version.
You are using an USA ArchiCAD version.
You should download the USA version of the ITG and it will show the same you see in your ArchiCAD.
Llian
Thanks!
I'm puzzled...I've checked and both my education version and the ITG downloaded from the myarchicad are 14 version. Anyways, I can find my way around with the tutorials as this is a minor issue.
OK, sorry, my bad. I have just checked the actual download page.
I thought there is a US version for the AC14 ITG, but apparently there is only an INT version.
Only the AC13 version of the Collaboration ITG is available in both INT (metric) and USA (imperial) version.
