stretching windows in S/E
Stretch command in menu isn't hidden with selected window in S/E... but it does nothing 😕
Is it just a bug or another AC9 feature lost by GS?
3 Replies 3
Probably just an oversight. Stretch has never worked in section. It is possible to resize doors and windows but that's different.
As far as I remember, sometimes I used Cntrl+H to resize windows because catching corner snap point sometimes resulted just in dragging a window... But maybe it was just a dream because I've tried to do it in AC9 a minute ago - surely no stretch command is needed
Anyway the problem in AC10 remains the same. You can't stretch windows horizontally if your cut plane is not parallel to the wall face
And you could before? I don't recall ever having tried.
