SOLVED!
sweeping in 3D
Hello!
Is it possible to sweep a profile along a line in 3D, for example along a spiral, going upwards?
Thank you!
1 ACCEPTED SOLUTION
Solution
Create a morph plane in the shape of the profile and then use the TUBE pet palette command to extrude it along the path.
7 REPLIES 7
Solution
Thank you for your answer!
Can I select which path I want to use I do I have to select part by part manually?
And if so, how can I adjust a complicated profile to for example spiral path?
I am pretty sure you have to pick the path points manually.
You can not adjust the path once it is created.
You will have to adjust each node of the path.
If you want something that you can adjust the path of easier then you could try the railing tool.
Alright, thank you again!
One more thing,
I don't find the option of creating a custom railing profile.
I can see that only railing panel and railing post can be created as custom.
Am I missing something?
tenak333 wrote:
One more thing,
Create your custom profile and be sure to set it for use with a rail.
Then in the rail settings choose the 'Profiled Rail' component.
Got it!
Thank you!
