‎2019-11-04 02:06 PM
Solved! Go to Solution.
‎2019-11-05 03:12 AM
‎2019-11-05 03:08 PM
‎2019-11-06 01:41 AM
tenak333 wrote:I am pretty sure you have to pick the path points manually.
Thank you for your answer!
Can I select which path I want to use I do I have to select part by part manually?
And if so, how can I adjust a complicated profile to for example spiral path?
‎2019-11-06 09:38 AM
‎2019-11-06 09:48 AM
‎2019-11-07 02:03 AM
tenak333 wrote:
One more thing,
I don't find the option of creating a custom railing profile.
I can see that only railing panel and railing post can be created as custom.
Am I missing something?
‎2019-11-08 12:49 PM
