sweeping in 3D
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-11-04 02:06 PM
Is it possible to sweep a profile along a line in 3D, for example along a spiral, going upwards?
Thank you!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-05 03:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-05 03:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-05 03:08 PM
Can I select which path I want to use I do I have to select part by part manually?
And if so, how can I adjust a complicated profile to for example spiral path?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-06 01:41 AM
tenak333 wrote:I am pretty sure you have to pick the path points manually.
Thank you for your answer!
You can not adjust the path once it is created.
You will have to adjust each node of the path.
If you want something that you can adjust the path of easier then you could try the railing tool.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-06 09:38 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-06 09:48 AM
I don't find the option of creating a custom railing profile.
I can see that only railing panel and railing post can be created as custom.
Am I missing something?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-07 02:03 AM
tenak333 wrote:
One more thing,
Create your custom profile and be sure to set it for use with a rail.
Then in the rail settings choose the 'Profiled Rail' component.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-11-08 12:49 PM
Thank you!
