symbols
i have a symbol with grouped objects and pasted it all over the drawings. but i needed to change the fill and i had to do it one by one all over the drawings.
is there a way where i can make the change in the symbol, in this instance, the fill, and the rest in all the other drawings will change automatically?
help.
ac7r3/xphome
Vitruvius
1. Toggle the "Options - Suspend Groups" button at the bottom of your display screen or on the menue.
2. Use "Edit - Find & Select" to pick the symbol by name.
3. Use "Edit - Tool Settings" to open up the symbols dialogue, change the fill and it should affect all of the selected symbols at once.
4. You can then untoggle the "suspend groups" button.
Cheers
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
You could 'file/gdl object/new' then draw the symbol in the '2D symbol' window and thaen save it as a regular library object. To make a glocal change just reopen the object and make the change.
