ā2008-08-31 05:26 PM
ā2008-08-31 05:45 PM
ā2008-08-31 05:56 PM
David wrote:nice and simple - thanks. just started using trace, so apologies if this was a silly question
One way to do this in ArchiCAD 12 is to set up a view with the desired Model View Options for fills, then use this View as the Trace Reference
David wrote:will do
You should add a Signature to your Profile (click the Profile button near the top of this page) with your ArchiCAD version and operating system (see mine for an example) for more accurate help in this forum.David
