2006-01-10 05:48 AM
2006-01-10 06:29 AM
2006-01-10 11:40 AM
Qutaibah wrote:Set the origin point to the position you want to start measuring from - the keyboard shortcut is to hold down shift-option (Mac) or shift-alt (Win) while mousing over the point.
Hi all. is there a tape measuring tool that would quickly give distance between tow points.
thanks Q
2006-01-10 12:44 PM
Dwight wrote:Or if you are using Teamwork, set the marquee tool to polygon mode and use this to measure within your workspace.
Sort of.
Draw a line between two points and watch the "delta r" value as you draw. When you hit the second pont, don't click or the value disappears.
2006-01-13 09:56 PM
