Learn more
teamwork problems
I am having problems when i want to chnage a window in my workspace it keeps on bouncing back to the original window when i send and recieve to the plp file.
Have the same problem with balustrades
12 Replies 12
vfrontiers
Another tidbit of information....
I wanted to fix the darn SCREEN OVERLAP in the TV object (graphisoft's)... SO naturally, you can't overwrite it (keeping the .lcf virgin)... so I SAVED AS "KHA_PlasmaTV". All was fine yesterday, but today I wanted to further edit it, so I selected in the plan and edited then hit SAVE... Instead of just overwriting my file from yesterday, it said that I "Already had a file named that and would I like to rename it?"
There IS something screwy with this ID stuff. I am NOT a programmer, so I can't debug this kind of stuff. Hopefully some can take the ball and run with it.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Did you check that it was writing to the same library? I find that AC often forgets where the part opened from and the save dialog comes up and points somewhere else. You should be able to redirect and overwrite.
vfrontiers
Yes I was able to overwrite by navigating to the correct place. I think the issue for me is that it should have never asked to save a NEW version if I simply chose SAVE. It should have known that it was THE existing object from the current library and simply overwrote it without a dialog.
Duane
Visual Frontiers
AC3.14 - AC29
