‎2008-11-18
03:59 PM
- last edited on
‎2023-05-26
02:44 PM
by
Rubia Torres
‎2008-11-20 07:28 PM
‎2008-11-20 07:32 PM
vfrontiers wrote:Did you check that it was writing to the same library? I find that AC often forgets where the part opened from and the save dialog comes up and points somewhere else. You should be able to redirect and overwrite.
Another tidbit of information....
I wanted to fix the darn SCREEN OVERLAP in the TV object (graphisoft's)... SO naturally, you can't overwrite it (keeping the .lcf virgin)... so I SAVED AS "KHA_PlasmaTV". All was fine yesterday, but today I wanted to further edit it, so I selected in the plan and edited then hit SAVE... Instead of just overwriting my file from yesterday, it said that I "Already had a file named that and would I like to rename it?"
There IS something screwy with this ID stuff. I am NOT a programmer, so I can't debug this kind of stuff. Hopefully some can take the ball and run with it.
‎2008-11-20 08:01 PM
