ā2009-01-09 05:02 PM
ā2009-01-09 05:37 PM
ā2009-01-19 01:59 PM
vistasp wrote:maybe misunderstood? well, simple example: there is a wall and I need to put a text on it ,we are talking that everything is in 3d view.I dont have a problem puting a text on surfaces at 2D, but you dont see them in generic perspective view
If you're looking for 3D text, the object exists in the library. If it's something else, then I've misunderstood the question.
ā2009-01-19 03:27 PM
ā2009-01-19 03:33 PM
David wrote:You will be laughing all day from my signature:) anyway thanks a lot for help
Aurimas:
2D elements (text, lines, etc) do not appear in the model (3D window). Using the Object Tool, change the "Folder View" to "Find Library Parts" and search for the "Text 3D" object to show text as part of the model.
David
ā2009-01-19 04:08 PM
ā2009-01-19 04:30 PM
"Leo Roitman" wrote:
Aurimas, you can also use textures for applying text to a particular surface. It takes much less resources of your computer, then 3D text does. But you'll see the text after rendering only (you are so sceptic about your configuration, so it might be not OpenGL-compatible). Anyway, read ArchiCAD help about textures and try to use them. If you have 1-2 specific surfaces, where you want to write some text - this way is for you. Mastering textures takes some time, but it worth doing.
Leo[/quot
I will try both, thanks a lot 4 advice, one more thing? what do you mean saying that my configuration could be not OpenGL compatible?
ā2009-01-19 06:15 PM
Aurimas wrote:You wrote about a lot of laughing from your signature, so I decided that your platform can be rather old. Actually it isn't. You don't describe your video card in the signature, so I can't say for sure, but it can support OpenGL.
What do you mean saying that my configuration could be not OpenGL compatible?
ā2009-01-19 09:58 PM
ā2009-01-20 01:15 AM
