text when hovering above icons disappeared
Hello!
I think I somehow accidentally turned off text popping up when hovering above tool icons, e.g. shell: extruded, ruled, revolved.
How can I get that text back again?
Thank you!
Erwin Edel
Help > Show Tooltips
If it says 'hide tooltips', then I think you might have some other setting turned off somewhere.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Thank you!
Solved!
