2006-10-16
05:45 AM
2023-05-23
03:25 PM
Rubia Torres
2006-11-18 04:08 AM
2006-11-18 03:40 PM
2006-11-18 05:37 PM
Andy wrote:I have long felt that polygon walls need to be able to be composites also. It might not solve your very complex condition, but it would take care of most circumstances I've run into.
Enclosed is a screenshot of one I drew a couple of days ago and had to patch.
My view is that there needs to be the ability of creating a polygon wall with its own patch symbol embedded in it, which can be edited as necessary. As to how this might work I don't know.
2006-11-20 12:18 AM
2006-11-24 09:29 PM
2006-11-27 12:51 PM
2006-11-28 11:43 AM
2006-11-28 09:49 PM
laszlonagy wrote:it is. but it's not the
I was thinking that using white pens on white background could be an option for not showing certain skins/fills/skin separation lines of Walls.
Another idea is to have the ability to have Pen 0 assigned to contour lines/skin separation lines/fill pattern lines. This would really make them invisible. (Having a white would still show and overlap other elemetns on a darker background).you mean in the 'model view options' settings? why not make each pen be capable of being transparent in the pensets?
2006-11-28 10:11 PM
~/archiben wrote:Yes, I agree, these are just workarounds.laszlonagy wrote:it is. but it's not the
I was thinking that using white pens on white background could be an option for not showing certain skins/fills/skin separation lines of Walls.solution. this seems to have been ignored by graphisoft for as long as it's been necessary to show core-only skins of the walls.
Yes, I meant the Pen Sets.Another idea is to have the ability to have Pen 0 assigned to contour lines/skin separation lines/fill pattern lines. This would really make them invisible. (Having a white would still show and overlap other elemetns on a darker background).you mean in the 'model view options' settings? why not make each pen be capable of being transparent in the pensets?
bottom line: we needmodelledcomposite skins (which would develop into parametric assemblies over time) so that we can have model view control over them . . .
~/archiben
2006-11-28 10:17 PM
laszlonagy wrote:being able to assign the pens-by-wall-function in the 'model view options' would be better though, no?
