the info box has disappeared
HI -
My info box has disappeared !
When I go to Window - Palettes - Info Box , the info box is checked. I have tried turning it on and off to see where it is with no luck. I have also moved all the drawings and dialogue boxes to see if it is hiding under something
I'm puzzled
Thanks for any advice -
John
1 REPLY 1
Erich
Try resetting your work environment to the AC standard environment. It should show up then.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
