‎2006-05-11 06:31 PM
‎2006-05-11 07:22 PM
Mo wrote:Sometimes it works for me in 9, sometimes not. Comfort: It's much better in AC10!
I can't seen to get this to work in 9
‎2006-05-11 08:16 PM
‎2006-05-11 10:19 PM
‎2006-05-11 11:52 PM
‎2006-05-12 04:05 AM
Mo wrote:If it wasn't for the window the solution would be very simple.
I know this has come up before back in version 8 and there was some talk about a bug fix. but I can't seen to get this to work in 9.
Three way wall intersections in section/elevation always give me an extra line in one direction or the other.
This means I need to detach the drawing and erase these lines. Over and over every time there is a revision.
Thanks
‎2006-05-12 03:47 PM
‎2006-05-14 12:14 PM
Mo wrote:You can also place a white fill with no edges over the undesirable lines. As mentioned, in 10 this situation is greatly improved, but there will probably always be occasions to use these little masks to keep the drawing live.
Thanks for your help everyone
Barry
I couldn't get the first solution to work for me although it raises the issue that this is more about joining walls at different heights than simply joining three walls. This was also alot of extra steps probably equal to detaching from the model and fixing it every revision
I like your second method and think that will be a easy fix . . . until I get ten then hopefully this will no longer be a problem.
‎2006-05-16 05:18 AM
Mo wrote:On some occasions there really is nothing you can do except for a white line or fill to hide what you don't want to see.
‎2006-05-18 12:43 AM
