trimmed wall showing in window
i have a gable wall for a shed dormer that has been trimmed to the roof below but it still shows it obscuring the window below (see attached) i've tried changing the view order, all floor plan display options. the cut plane is set to 4'
4 Replies 4
second pic
David Maudlin
wildernessbob:
One option is to Split the wall at the perpendicular wall, and place the obscuring part of the wall on a layer for 3D elements (hidden in the arch plan view).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erwin Edel
I use these windows https://bimcomponents.com/GSM/Details/7436 to make the hole that is needed and set floorplan display to projected instead of symbolic. This creates a proper floorplan display of the wall.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thanks, i'll try the separate layers. it also solves another issue with walls that i've been having.
wb
