Space_Agency
trying to model a basic ABS combi-wye and 1/8th bend in V29 MEP. Still a train wreck of a product
MEP tools still barely usable. Graphisoft, please simplify this. Actually sit down with an architect and have them try and model basic PVC/ABS fittings.
Has anyone been able to make standard US PVC or ABS combination wye and 1/8" bend with these tools? And then consistently deploy that in pipe routing?  For example, I can't rotate a wye 45º along the pipe axis? only 90, 180 or 270? I find the interface to be a ton of moving back and forth between settings when I just need to see the damn visual representation change as I enter ALL the parameters in one place. And I can't get it to work to make most basic fittings as there are constraints set up in the "pipe combination wye" object.  So frustrating we are still here version after version release with an unusable full of bugs implementation.
Archicad V29 /V28 USA
MacBook Pro M1 Max
ram 64GB
Mac OS Sonoma 14.2.1
0 Replies 0
