dhnguyen
turning off other stories
I'm working on a drawing that's built by someone. It has several stories. I want to turn off those stories in 3D view except for the 3rd story so I can see it in 3D.
When I click on the 3D tab in the project map, all the stories are turned on... does this mean I need to manually turn off all other stories except for the 3rd story, and save the view?
.. if that's the case, how do I change the view to elevation view so I can select elements and turn them off?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Solution
Eduardo Rolon
Check under menu: View -> Elements in 3D View -> Filter and Cut Elements in 3D
There you can define and show whichever stories you want
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
3 Replies 3
Eduardo Rolon
AC29 US/INT -> AC08
dhnguyen
thank you!
DNguyen
ArchiCAD 18- 25
Or go to the 3rd storey in plan (or any other storey you want), select all (CTRL+A), right click and show selection in 3D.
This saves messing around with the filter settings.
