twisting....????
dear friends
how can i twist a shape around a centre ,for example twisting a column around a point out of the column ,without touching it.
hope to get a help:)
hana farhadi
4 REPLIES 4
Djordje
vian wrote:
dear friends
hana farhadi
Sounds like you would need MaxonForm.
Can you post a screenshot so that we can see what EXACTLY do you need? Maybe it can be solved in a different way.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
why not ArchiForma?
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Djordje
Fabrizio wrote:
why not ArchiForma?
Oh, definitely!
Also, the GDL Toolbox is now free ...
Djordje
HP Omen
Yes, Nik, that's right.
AF is great for twisting one profile into another, for example, But, to take an arbitrary chunk of model, created using any tools whatsoever, and twist it, MaxonForm is the answer. For example, if you were modeling a creepy house for Disney with windows, doors and all other elements and then wanted to twist the entire thing in an even creepier way ... only MaxonForm will do that.
Perhaps hana farhadi can post an image of what he/she wants to accomplish and we can all offer better advice.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
