justdhruv
viewing active story only.
Is there keyboard short cut or command for viewing only the active story. I already know about the cmd+opt+A, but is there some other way as well? the idea of going to a dialog box every time does not sound too good.
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
4 Replies 4
TomWaltz
In what window are you trying to see it?
Tom Waltz
Link
The Filter Elements in 3D dialog will remember the current settings until you change it. If you want to continually show different stories in 3D, I would recommend using the marquee tool. Set the selection method to Single Floor (thin marquee) and encapsulate all of your elements. This will remain current for all stories.
Link.
justdhruv
i am working on a project with 12 stories. In the plan view i see elements on other stories as well. what i would want to do ideally is that, i double click on the story in the navigator palette and see only the active story.
shift + F2 should turn the ghost story on and off
