visible line in beam
hi all
When I draw beam with profile in the plane I can see outer line of it and center line
any way to see every visible line in it
8 Replies 8
Erika Epstein
Unfortunately not.
You can make a library part of this fairly easily and then you will see the lines.
You can then lengthen it as necessary when you stretch in one direction only. Assign it the subtype of beam.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
thank you
but I hope to know why AC do that what the Idea of this?
Erika Epstein
Nour,
Can you please add to your PROFILE your operating system and version of archicad.
And is your name Nour? or Queen?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
You could model this using the Wall Tool and for a Wall you can set the Floor Plan Display to "Projected" so you will see those lines.
thank laszlonagy but wall have not angle to skew verticaly.that what I need
How about a Column?
You can create a slanted Column and it can be set to Projected.
The only restriction is its slant angle to horizontal must be at least 1 degree.
How about a Column?
I try column nothing right ??? please can you attach pic of that
I need verticaly profile (beam,wall ,column....) with slant up angle
and why when select projected in beam visible line not appear.
thank you
Here is an example.
On a second thought, maybe this is not what you are after because it shows the Cut surface. So you would have to increase the Floor Plan Cut Plane to be above it. But maybe you don't and it works.
