‎2007-08-19
01:41 AM
‎2023-05-23
03:16 PM
Rubia Torres
‎2007-08-21 09:47 PM
‎2007-08-22 12:15 AM
‎2007-08-22 12:31 AM
Chris wrote:If the design is finalized, I'd use Trim to roof. (trim the bottom with a temporary or hidden roof.
What is the best, most efficient way to add a wall object that follows the gable end profile of a roof object, (meaning that its top and bottom are both angled)?
‎2007-08-22 01:04 AM
Laura wrote:Here's a screenshot - the light grey area of the roof is what I need to cover with a wall. The I'd be adding finish cladding, rakes, and soffits with either cadimage accessories and/or complex profiles.
I suspect your answer will have to do with SEOs, but it's really hard to get a clear understanding of what you're describing -- can you post a sketch or screen shot?
‎2007-08-22 01:54 PM
Chris wrote:That would be the Beam tool, if you want to avoid cutting a wall with Trim to roof or SEOs like described above. You can also make a custom profile for the "beam" if you want. I've no idea of how it interacts with Cadimage, though.
If AC simply allowed for sloped walls with consistant height, it's be simple......
‎2007-08-22 07:34 PM
‎2007-08-22 10:01 PM
‎2007-08-22 11:58 PM
Chris wrote:you're talking about a barge-board right? if you are using the cadimage accessories why not use 'roof builder' to add the roof edge and flashing details too?
‎2007-08-23 01:20 AM
~/archiben wrote:Well, I'm almost talking about the barge-board, but in this case the eave and bargeboard are of a smaller dimension than the roof structure. Since I'm planning on using the cadimage accessories to add clapboards to the walls, I therefore need a wall object in front of the roof (where the sheathing will be in reality) so that I can attach the clapboard wall object up to the bottom of the barge board.Chris wrote:you're talking about a barge-board right? if you are using the cadimage accessories why not use 'roof builder' to add the roof edge and flashing details too?
~/archiben
