2007-08-19 01:41 AM - last edited on 2023-05-23 03:16 PM by Rubia Torres
2007-08-23 03:38 AM
Chris wrote:not really - just set the wall builder to 'follow...' the top of the wall and offset it down by a negative amount. the wall cladding will then extend upwards from the actual top of wall. (in reality it's going to slide underneath the barge flashing anyway right?). and then configure the barge flashing to extend out over the cladding.
Well, I'm almost talking about the barge-board, but in this case the eave and bargeboard are of a smaller dimension than the roof structure. Since I'm planning on using the cadimage accessories to add clapboards to the walls, I therefore need a wall object in front of the roof (where the sheathing will be in reality) so that I can attach the clapboard wall object up to the bottom of the barge board.
Since I am planning to use the cadimage accessories for eaves and soffit - how do you find them? Any giant hits or misses with the tool?i find them far more satisfying than working solely with the archicad toolset. there's something a bit more 'BIM' about working with them: there's little fudging - you have to solve the details.
2007-08-23 07:34 AM
2007-08-23 08:02 AM
Chris wrote:you've got it!
This might be what was described the earlier responses, but I was so focused on my little path walls of sheathing to be applied to the face of slabs and roofs that it all didn't click until just now.
