‎2006-04-13 02:36 PM
‎2006-04-13 03:04 PM
archimax wrote:If all else fails you can draw a white line over the intersection. this will cover it up.
Is there any way to remove such lines without unlinking elevations.
‎2006-04-13 03:39 PM
archimax wrote:Tom's Patented Easy Way:
I've tried to use wall ends (...awful tool) but can do nothing with lines appearing in the elevations. The connection between wall-end and the wall is shawn with a line. And the same is for wall-ends above each other.
‎2006-04-13 04:02 PM
